Fourth generation iPhone. Repair is straightforward, but the front glass and LCD must be replaced as a unit. GSM / 8, 16, or 32 GB capacity / Model A1332 / Black and White. This page aims to help users troubleshoot, fix, and seek help for the iPhone 4.
4s Back Panel Is Stuck On
I have removed both screws, but the back panel will not slide up. I’ve tried increasing pressure, cleaning the sides with alcohol and increasing grip with some gaffer tape. I can’t replace the battery if I can’t open it. What am I doing wrong?
Add a comment
1 Answer
The battery is probably expanding and putting pressure on the back glass making it harder to slide up. I would try putting the phone face down on a non slip surface like a rubber mat or something then slide the back up while putting slight downward pressure on the phone.
2 Comments:
Hi Jay, I'm jumping in on @xnriqux's answer. If you think the battery could be swollen, make sure to be really cautious working on you device. A swollen battery is quite dangerous–it can be a serious fire hazard. Check out our wiki on swollen batteries before you attempt your repair so you can be extra cautious! What to do with a swollen battery
by
@amber Thank you!
by
Add a comment
Add your answer
Jay Hackens will be eternally grateful.
Past 24 Hours: 2
Past 7 Days: 9
Past 30 Days: 21
All Time: 125
