Released November 4, 2017. Model A1865, A1901. Available as GSM or CDMA / 64 or 256 GB / Silver or Space Gray. (Pronounced the same as "iPhone 10.")
new screen won't attach-- metal tabs broken off?
My son removed the screen on iPhone X (to replace battery) and broke the screen. So ordered a new screen, hooked it up, but when I go to reassemble, it doesn’t want to click-in to the phone body. I’m noticing the removed/broken screen has no metal tabs on the edges, but the new screen has several. Could these metal tabs be broken off in the phone body?
Add a comment
1 Answer
Chosen Solution
More than likely when the screen was removed, the actual display came free from the frame it’s mounted to. Included images for reference of what the inside with no display should look like. The silver bit around the edge of the back of the display is likely still seated in the enclosure. You should be able to pop it out with a tool, just be mindful of the battery and other components. The clips just snap in place and will come free with enough force.
Score 3
4 Comments:
This was exactly it. I was able to remove the bracket and attach the new screen. Thank you very much!
by
Thank you for this post!!!!
by
Yep, me too! Perfect!
by
@kcirsnurb Glad people are still running into this and finding it helpful :)
by
Add a comment
Add your answer
sethcrothers will be eternally grateful.
Past 24 Hours: 2
Past 7 Days: 5
Past 30 Days: 34
All Time: 1,917
