15% Off Selected iFixit Tools — Limited Time
2.2 GHz (Turbo Boost up to 3.4 GHz) or 2.5 GHz (Turbo Boost up to 3.7 GHz) quad-core Intel Core i7 processor with 6MB shared L3 cache.
MacBook Pro speaker Cracking
Hello everyone,
I have a Macbook Pro 15” mid 2014 and my speaker started crackling. When i put it at full volume and play some music it starts crackling. I really don't want to replace theleft speaker.
Has anyone else encountered this issue ?
Thanks
Add a comment
1 Answer
I’ve replaced quite a few speakers, most of the time the diaphragms get ripped from over stressing the speakers. They are not designed to fill a room (even a small bed room).
So cranking up the volume to the top is not something I would recommend. Get a pair of bluetooth speakers or cheaper wired speakers at least then you can throw them away and get another set if you really need to hit the decibels! I should also point out the volume mid point is as high you should be running at otherwise you run the risk of damaging your hearing with a speaker so close to you. I also find the older MacBook Pro’s don’t have the best speakers so if you really want some decent fidelity get a set of externals.
Add a comment
Add your answer
HONZA NUGETA will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 6
Past 30 Days: 12
All Time: 152
