Released alongside the AirPort Extreme base station, this hard drive equipped variant offers 802.11ac speed on a time capsule NAS.
Time Capsule Won't Power on, PS seems good
I swapped power supplies with an AirPort Extreme and it worked in the Extreme, so I’m thinking a board issue.
Any leads here?
2 Comments:
Is the LED lit?
by
@danj nope, no signs of life
by
Add a comment
Not good ;-{
You could try disconnecting the drive to see if that is clamping the power (shorted out), otherwise you have a logic board issue which will be hard to diagnose as there are no publicly available schematics or board views to reference.
Add a comment
Triple check all the flex cables - either you may have not connected them well enough or some of them may have torn accidentally - if possible check their continuity with a multimeter and some really thin probes.
P.S.: I’d even start with checking if the power socket wires are soldered as they should after reassembly and if they are still continuous - if not this could be an easy fix
Add a comment
Add your answer
Jon will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 8
All Time: 225
