iMac CPU and RAM swap-out between two systems
Would it be possible to put the CPU processor and RAM memory of an iMac Late 2012 into an iMac Late 2013?
I’m not sure its worth the effort to take a 2012 21.5” CPU and put it into a 2013 21.5” system as the 2012 CPUs are an older technology Ivy Bridge vs Haswell the systems BIOS micro-code may not allow it.
As far as RAM both systems use the same RAM but this series only has two SO-DIMM slots, your system will either have two 4GB (8GB) or two 8GB (16GB) SO-DIMM’s so unless you have the larger set to put into the other logic board it won’t gain you anything.
This is a lot off work with little to be gained even if you had a i7 CPU
Reference:
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 19
