The Jeep Liberty is a compact SUV that was produced by Jeep for the model years 2002–2012.
Will this procedure program my new FOB Key when only have one orig key
Ron T <jlodoggy1@gmail.com>
6:23 PM (5 hours ago)
Programming a Single Key
 This is what I have  a Jeep Liberty 2011 low miles mint with one working Key fob because the other key chip they used to hide under the dash for my electric start  , so now with one working Key Has anyone proved out this  procedure will work with one new cut  Fob Key that's not programmed yet .should I take a chance to do this?
A handful of manufacturers will allow you to program a single key, even if you don’t have a key that works. Keep in mind that you’ll still need to have the key cut to fit the ignition, which means you’ll need to provide proof of ownership to a locksmith.
That said, the process is much simpler than programming a second or third key:
  • Insert the key into the ignition, and turn it to the on position. Don’t turn on the engine, only the electronics.
  • Leave the key in this position for 10 minutes and 30 seconds, and then turn it off.
  • Turn the key back on, and wait for additional 10 minutes and 30 seconds before turning it off again.
  • Repeat the process for a third time.
  • Return the key to the on position, and it will program the key.
  • Test your new key by turning on the ignition
1 Comment:
THANK YOU what I did was buy a blank FOB had it cut then went to a locksmith and they programmed, I should have tried the advice above first however I didn't know this .
by
Add a comment
1 Answer
Honestly the easiest and best way is to find a locksmith and they can program a second FOB for about $50—$90 (depending on the FOB cost.
Add a comment
Add your answer
Ronald Tyler will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 13
All Time: 338
