Slim, lightweight and stylish, the Swift 3 is the ideal laptop for working on the move. The latest NVIDIA® GPU, Intel® CPU and long battery life are housed inside a choice of displays: an elegantly silver chassis with a 13.5” 3:2 ratio 2256x1504 IPS VertiView Display or the vivid colors of a 14” 16:9 FHD IPS display.
18 Questions View all
My laptop won’t turn on and is flashing orange lights
On my Acer laptop there is two orange flashing lights on the side, it won’t turn on, I’ve tried turning off all power adapters and holding it down for 30 seconds. Nothing has worked and it’s still not turning on, can someone please help me
Score 3
2 Comments
Werkt bij mijn niet Ik heb ook geen batterij reset
by
I have a laptop acer travelmate spin b3 series. I tried to open it but i didn't open so i plugged the charger and the orange light on the side and on the lid started blinking slowly. Then after searching some reasons for almost 30mins it the light on lid started to blink blue for a while then orange. But the light on the side is still orange. How to fix it ?
by
Add a comment
Most Helpful Answer
When the battery charge is low the orange light will blink slowly. When the battery charge level is critically low (less than 3%) the orange light will blink rapidly.
But in your case it is fully discharged.  So please follow the steps below
If the battery is not charging with the AC Adapter, perform a power reset:
  1. Remove the battery and unplug the AC adapter or the power cord from the computer.
  2. Press and hold down the power button on the computer down for 30 seconds and then release the button.
  3. Plug in the AC adapter or power cord again, reinsert the battery, and power on the computer.
If the Battery is non removable
Turn off the computer.  Unplug the power cable.   Turn the laptop upside down.
If your system has a battery pinhole reset on the bottom, insert a small paperclip in the battery reset pinhole and hold the button down for 5 seconds.
Connect the power cable and turn on the computer.
Score 6
4 Comments:
thank you very much. it helped me a lot.
by
Yep worked geat on one Acer but not on second one, so new battery ordered off Flebay..!
by
Thanks very much, that worked
by
I don't have a removable battery nor a pinhole so what so I do
by
Add a comment
We had this problem on an Acer Nitro 515-54, nothing worked to fix it. THEN we looked at the BIOS and it was on version 1.01. Downloaded 1.33 BIOS and it fixed the problem. Good Lord! Really Acer?
1 Comment:
My Acer Aspire 5733Z started flashing the blue and orange LEDs.
If I disconnected and reconnected the charger the flashing stopped until what seemed be when the battery charging resumed.
I replaced the charger and now my good ol' Acer works again.
by
Add a comment
I have a laptop acer travelmate spin b3 series. I tried to open it but i didn't open so i plugged the charger and the orange light on the side and on the lid started blinking slowly. Then after searching some reasons for almost 30mins it the light on lid started to blink blue for a while then orange. But the light on the side is still orange. Then whenever i try to lift up the lid. The light on the lid vanishes then the orange light on the side becomes blue. How to fix it?
Add a comment
Add your answer
Potato Potato will be eternally grateful.
Past 24 Hours: 40
Past 7 Days: 202
Past 30 Days: 1,023
All Time: 63,366
