Fourth generation iPhone. Repair is straightforward, but the front glass and LCD must be replaced as a unit. GSM / 8, 16, or 32 GB capacity / Model A1332 / Black and White. This page aims to help users troubleshoot, fix, and seek help for the iPhone 4.
2375 Questions View all
What Type Of Screwdrivers to open iPhone 4?
Hello,
I mean the screws inside the iphone 4, not the 2 screws located in the charge dock or back cover, I'm talking about all the screws after screwing those 2 off and opening the back piece of the iphone 4. I almost purchase every tool there is, and all they can do is open the 2 bottom screws. Can someone tell me where can i get them, either online or in life, and tell me the exact name to look without getting mixed up with the screws that can only open the bottom 2 screws of iphone 4.
Score -1
2 Comments
at the top of the guides..linked on the right under the photo of the phone it tells you what tools you need. i believe it's a philips head(ph) #00..all you have to do is check before you start and you should be fine.
by
Yes but i purchased a bunch of them on ebay/amazon and all they do is screw off the 2 screws on the charge dock.
by
Add a comment
Chosen Solution
The Phillips screws on all iPhones including the iPhone 4 is standard Phillips #00. But manufacturers are sloppy so you may have to try a couple of screwdrivers to get a good #00. Also inside iPhone 4 you will need a very small standard flat screwdriver. When you get good screwdrivers, run a simple magnet along the length, straight off the tip to magnetize them for your iPhone repair work. Keep your iPhone screws in good order, they are all different lengths.
Score 2
Add a comment
you have two type of screw driver:
=>the first one is a classic cross screw driver
or
=>pentolobe screw driver like this one
Link text
Add a comment
Add your answer
sogamichael will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 1
All Time: 16,029
