Second generation of iPhone. Model A1241 / 8 or 16 GB capacity / black or white plastic back. Repair is more straightforward than the first iPhone. requires screwdrivers, prying, and suction tools.
1158 Questions View all
Dropped iPhone and now has blank screen ...?
I dropped my iPhone and now has black screen. display not showing, phone still working, calls coming, and I feel touch system also not working.
What should I do?
Score 1
Add a comment
Chosen Solution
Reset, Hold both Home and Power buttons until the White Apple shows, usually about 15 seconds time. If that does not work, possibly the Screen Flex Connectors #1, #2 came loose from the Logic Board. If you can turn OFF iPhone, hold both buttons again for about 3-4 seconds, then release them, see if vibrate works if not, hopefully it is OFF. Carefully open iPhone and check to be certain both connectors are properly seated.
Score 3
1 Comment:
Okay! Thank you. I restart, on off, but it seems to be connectors problem. I should go to service center.
by
Add a comment
Also check your iphone's screen under bright light. If your backlight IC damaged you still can see everything but in a lightless way..
Score 1
1 Comment:
No seen anything, it is blank!
thats Connectors problems
by
Add a comment
Add your answer
Maliklbw will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 9,693
