Resistors and capacitors vaules around power supply part?
Hi everyone!
So i got xbox one S form friend. Xbox was flooded by a cat urine :C. a lot of rezistors and capacitors around power supply part are just very very rusty. I need to know values ALL of them to buy new ones.
Btw i know that this “fix” is probably not worth it so please do not write anything like": “let this console die” or “it’s not worth , buy new one”
Thanks for help!
Update (10/29/2021)
I send more pictures after more detailed cleaning
Update (10/30/2021)
And parts that i think are good to replace:
https://pl.aliexpress.com/item/400032469...
https://pl.aliexpress.com/item/330014307...
https://pl.aliexpress.com/item/329611170...
Update (10/30/2021)
So i unsolder memory(i guess it’s memory and it looks just fine. Now it’s time to clean it up and solder it back. Wish me luck
Sorry for bad quality of pictures, my phone camera isn’t as good as my canon
Update (21/11/2021)
Here I enclose some pictures. I need to buy sd card adapter. For this moment i just took photo of my microscope LCD :]
This one is ok
Here’s are this “3” pads that become “1”
Update (23/11/2021)
https://pl.aliexpress.com/item/330546860...
https://pl.aliexpress.com/item/329344270...
https://pl.aliexpress.com/item/100500258...
Update (27/11/2021)
C915
R9C29
R9C30
R9C22
R9C31
R9D5
R9D8
C9C19
R9C19
C9D18
R9D25
R9D26
R9D29
R9D17
R9D30
C9D17
R9D20
C9D8
C9D11
C913
C9C3
C9B5
C9B2
C9B7
C9C5
Update (5/12/2021)
19 Comments
Can you give us the model and revision number of your power supply?
R9D33: 2.2 ohms
R9E3: 1 Ohm
by Andrew S
@andrewsawesome model N15-120P1A rev 03 , just to be clear it is NOT part of the power supply exactly but the part of mainboard where pins of the power supply goes :V. And thanks fore the respond ane values <3
by Paweł Ordowski
@werfex clean your board with some 96%+ isopropyl alcohol and a soft brush first. Of course, best way of cleaning that particular board would be with an ultrasonic cleaner, but if you do not have that use the aforementioned method. Then post a picture of that clean board with your QUESTION as well. You really have to narrow it down otherwise you will be looking at an extensive repair and most likely could get a replacement board for lot less time/money. But lets see what we can find out about all of this once its clean.
by oldturkey03
I agree with the above comment, clean the board very well and see how things look then. Out of those components the most likely to be bad is the small chip just above the rusty capacitors in your pic.
by Phone Menders
@oldturkey03 so to be honest, it was already cleaned, it is still dirty on pictures bc it is just very old, i mean my firend left it for ONE YEAR, I probably need to use hot air to remove this mess(yes i used isopropyl). My question is very difficult i guess bc i need values of all capactiors and all rezistors in this area. Microsoft didn't share schematics of this console so i have no chooice.
by Paweł Ordowski
Show 14 more comments
