A1180 vs A1181 interchangability
Question, is the Macbook a1181 an updated version of the a1180? I have a a1180 with a broken screen and a a1181 with a bad keyboard these guys aren't interchangeable are they?
Mike
Mike
Well actually I'm not sure about the interchangeability. But it's easy to verify. Replace the entire upper case following this guide.
MacBook Core 2 Duo Upper Case Replacement
Note that it will also replace your trackpad. If everything connect well and if the screw goes at the same place, the rest should be working
Or try to replace the entire display assembly.
MacBook Core 2 Duo Display Replacement
But the display includes the airport antenna and the inverter, so you'll have to check if they work
Guide
Difficulty:
Moderate
45 minutes - 2 hours
Guide
Difficulty:
Difficult
1 - 2 hours
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 1,148
2 Comments
So are the upper cases interchangeable? Can I used the earlier one on a later unit?
by mike
They look the same from the outside. Some of the functions on the top row of keys are in different locations.
I think I'll try it. How hard could it be?
by mike
