Released November 4, 2017. Model A1865, A1901. Available as GSM or CDMA / 64 or 256 GB / Silver or Space Gray. (Pronounced the same as "iPhone 10.")
Screen detached from frame
My screen had already come slightly loose, so following the guide for the screen replacement (iPhone X Screen Replacement) I got the screen separated from the device. Step 12 says to make sure the frame comes with the screen, but I believe mine is stuck. Since the screen is partially attached to the frame, I need to get this frame out. How can I do this?
1 Comment
I realise this may be due to not removing the screws at the bottom. If I remove these will the frame just drop out?
by
Add a comment
Chosen Solution
The side clips are friction clips, they can be pulled out with enough force.
The top clips are actually hooks, you need to lift the screen from the bottom to release the top hooks, which is why locking the bottom with screws ensure the screen frame is locked in place on both ends.
Score 2
2 Comments:
Is there a way to rejoin the screen to that inner frame? Or is that part of the waterproof seal?
by
@cybnz Industrial grade permanent adhesive.
by
Add a comment
Most Helpful Answer
Yes the pentalobe screws will be stopping the whole assembly from coming out. You must remove these before removing the screen.
Score 2
Add a comment
Add your answer
Ben Jones will be eternally grateful.
Past 24 Hours: 3
Past 7 Days: 9
Past 30 Days: 31
All Time: 2,758
