What does F11 mean?
Tried unplugging, and restarting.
F11 is an indication of a communications problem.
Communications cannot be sent correctly between the machine control board and the motor control board.
Here are some possible causes:
Loose wire connection at either the machine control board or motor control board.
Machine control board failure
Motor control board failure
Door lock
Motor
Error codes can be caused by a Power Surge or other electrical anomaly, attempt to return the washer to operation by following the
Hard Reset
procedure below.
In some cases the control can be non-functioning or may not accept activation from the control panel. To clear and restart the control follow the these steps:
Unplug or turn the circuit breaker off for 10-20 minutes.
Reconnect the unit to the power source by turning the breaker back on or plugging the unit back into the wall outlet.
Press the Pause/Cancel/Stop button twice to clear the display.
Start a short cycle to check the operation of the machine by selecting a cycle and pressing and holding the start button until the machine starts.
Without a model number I am unable to provide you with specific information. For further assistance resubmit your question with the complete model number.
Hi, you seem to be an expert, and I thank you for sharing you experience.
What would be the Hard Reset for a Whirpool GHW9400PL1 washer?
Many thanks
Leonardo
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 14
All Time: 209
