Released June 2009 / 2.66, 2.8, or 3.06 GHz Core 2 Duo Processor
300 Questions View all
Mid '09,won't boot off HD or OSX DVD
Has booted twice from DVD, once locked at language selection screen, 2nd time made thru language select screen, then "gathering" HD info and stopped. Left it searching over night. Now it won't boot from DVD. Used C key on startup, D key on startup, Option key on startup and Shift key. Comes up with apple logo, spinning wheel below, optical drive spins up, reads from DVD, can hear the chatter of the read head, then after about 2 minutes, DVD spins down to a stop and nothing more happens. Apple logo still on screen with spinning wheel below frozen. Have reset PRAM and/or NVRAM. Seems to get very warm on the bottom left rear of the case.? When booting with the Option key pressed, it does come up with the OSX DVD select option on the screen, I select it, it starts reading the DVD, then it comes up with the apple logo and spinning wheel, reads a little more from the DVD, spinning wheel freezes, DVD then spins down and "nothing".
Score -1
Add a comment
1 Answer
Chosen Solution
Remove the hard drive and see if it will boot OK from just the DVD. If so, replace the hard drive. Here's how: MacBook Pro 15" Unibody Mid 2009 Hard Drive Replacement
Score 3
1 Comment:
Yep, it now boots from OSX dvd. Time to shop for a new hard drive.
Thankfully I did a Time Machine backup about 2 days before it died. 1 more question Mayer, should I get a SS drive for this machine? I worry about dependability and longevity.
Thank You Mayer
by
Add a comment
Add your answer
Kelly will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 2
All Time: 424
