Released in July 2018, the 15" MacBook Pro, model A1990, features a 15.4 inch LED-Backlight display with True Tone technology, TouchID, and up to 6 Core i9 Processor.
Unable to do software upgrade, what could be wrong?
Bought a 2018 MacBook Pro 15” from a 3rd party recently, which has Mojave installed and running fine, however, try to upgrade it to Big Sur or Catalina, it always return the following message (a small window pops out, which is about 9 or 10 minutes left toward finishing):
“An error occurred installing MacOS. You may try again to complete the installation”
Firstly I thought it might be something wrong with Apple server, but have this message shows up every time doing software upgrade, so, I think it must be something else.
Does anyone have any thoughts what could be wrong with this laptop, or some hidden settings which prevent the OS to be upgraded?
Thanks,
Add a comment
1 Answer
As this is a used system are you able to contact the original owner to have them remove the system from their iCloud account?
Sadly, your system is linked as it won’t allow you to alter the drive until it’s either logged into iCloud or the system is removed from the users equipment listing.
7 Comments:
How do I know it has iCloud account linked with others?
by
Your error tells me
by
@danj - Is there a setting I can verify? By checking the iCloud from system reference menu, it didn't show anything there.
by
@lovecd - If you knew the persons iCloud ID and password you could verify it (and even fix the issue)
The other option is visit an Apple Store to have them help you.
by
@danj - I'm a little confused, so, there is no way to check the settings upfront even the iCloud field from "system reference" was not filled up? I'm curious to know if there is a way to check it before purchasing used MacBook Pro from others in future time.
Thanks,
by
Show 2 more comments
Add a comment
Add your answer
Tom will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 14
All Time: 147
