Reboot and freezes when using USB / Wifi
Hi. I got a second hand iMac. The machine boots OK, i could install systems (tried 10.11 and 10.13). The Mac works correctly (seems), as long as I don’t use a USB scanner or try to access the internet.
When I do, I get all sorts of weird things: black screen and reboot (also happens some time when just using software), grey screen (most often), blue screen (once), other screen colors - in any case it freezes and will only boot again after resetting the PRAM (several "sound + reboot” for about 20 seconds). Replacing RAM did not help.
I have to decide if I try some repair or break the machine into spare parts. I think it’s a board problem, but which board?
Have you tried running the onboard diagnostics yet? Restart your system and press the D key
Reference: Mac startup key combinations Let us know how it goes
by Dan
I did. Diagnostics don't show anything.
by Thierry de Coulon
