Model A1312 / Mid 2011 / 2.7 & 3.1 GHz Core i5 or 3.4 GHz Core i7 Processor, ID iMac12,2
708 Questions View all
Reboot and freezes when using USB / Wifi
Hi. I got a second hand iMac. The machine boots OK, i could install systems (tried 10.11 and 10.13). The Mac works correctly (seems), as long as I don’t use a USB scanner or try to access the internet.
When I do, I get all sorts of weird things: black screen and reboot (also happens some time when just using software), grey screen (most often), blue screen (once), other screen colors - in any case it freezes and will only boot again after resetting the PRAM (several "sound + reboot” for about 20 seconds). Replacing RAM did not help.
I have to decide if I try some repair or break the machine into spare parts. I think it’s a board problem, but which board?
2 Comments:
Have you tried running the onboard diagnostics yet? Restart your system and press the D key
Reference: Mac startup key combinations Let us know how it goes
by
I did. Diagnostics don't show anything.
by
Add a comment
1 Answer
With no error its a bit of a hunt and peck ;-{
I would start off with the power supply and then you’ll need to look deeper into the logic board circuitry.
3 Comments:
OK. but what do I look with the power supply? How to test it? Actually, same question with the board. I mean if it does not show from outside...
by
@tcoulon - I would just replace it unless you have the skills to test it,
by
OK, I unmounted the screen. The board of the power supply is full of white marks, I guess it's a bad omen... The other boards "look" good.
by
Add a comment
Add your answer
Thierry de Coulon will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 23
