Scroll through this thread to find the appropriate place for this comment. Then, click "Attach comment to this post" to move it.
6 Comments:
Is it only during acceleration? Have you tried fuel treatment to clean the system? Could potentially be motor mounts as well. Pop the hood n fire it up. Have someone put it in drive, and reverse. Does the motor look like it moves when you do?
What is the year/make/model? It sounds like a CV joint is going. Do you hear clicks or thunks when making sharp left/right turns? CV joints are known to cause vibrations when accelerating
by brandon k
I did the fuel treatment for several tanks and nothing has changed. I'll look at engine and check it out. It's a 2017 canyon and this on
Y happens after speeds of 40 and above.
by Ed Olson
by brandon k
2017 canyon, no noises at all just vibrates when accelerates. Really notice it in cruse control. On and off.
by Ed Olson
Definitely sounds like cv joint. Check them to see if the boots are damaged. If they are... time to replace. https://axleaddict.com/auto-repair/Car-V... should help.
by brandon k
Show 1 more comment
