SSD Upgrade for Non-Fusion HD
Hi - come here for expert help.
I have a late 2014 Mac Mini (MM) with standard SATA 1 TB HD. It's slow. So I started researching upgrading to SSD to speed things up. I have a few thoughts/questions:
1) What's up with Fusion Drives? I understand it's the mating of traditional HD and SSD to speed things up. So during the SSD upgrade does it only make a traditional HD faster? Are they not a unified system as designed?
2) Somewhere on the webs there is a procedure to "trim" SSD from MM HD. What does this mean? Does this mean separate HD from SSD to create two separate volumes?
3) Can my non-Fusion MM be upgraded? If yes how (links to web pages/products appreciated).
4) I did see an install instruction to remove old traditional HD and replace it with an SSD HD using the SATA connection. Shouldn't this be the way to go for my MM? Is this just as fast? If yes why would adding an additional blade SSD using Apple's propreietary connector be helpful? Is this just a way to add two separate storage options (one SSD HD coupled with SSD Blade?
5) Please recommend SSD SATA drives or Blades that will give me best buck per performance. I realize the bus speeds on my Mini are probably slow - so no overkill. This is what I installed in my Macbook 2014 -
ADATA XPG SX8200 Pro 1TB.
6) Can I add an traditional SSD Sata Drive along with SSD Blade? Most installs just showing a SSD Blade being installed.
I am clueless. All of the info I read on the webs does not help at all. I went to iFixit (as recommended) and there was no "SSD Instal Kit" for my 2014. There are links to a bunch of Chinese cables to supposedly help with install, but I still don't know if my MM can even have it installed.
Please help with clear answrrs/instructions
Thanks
Jerry
