Released October 24, 2011 / 2.2, 2.4, or 2.5 GHz Quad-core Intel Core i7 Processor
I can't install mac OS it goes to the white screen but runs Windows 7
Hello there,
I have a MacBook Pro 15” Core i7 2.2 GHz Late 2011. I can't install macOS it goes to the white screen but it runs Windows 7
I want to install macOS High Sierra but after first shut down, it goes to the white screen, Also some times it has thick yellow lines on the screen but I don’t have any problem if I use windows on it.
Add a comment
1 Answer
Your Mac has two graphics systems!
The discreet AMD GPU (DG) has a problem, but your Intel CPU’s Intergraded graphics (IG) services is still working! So what you are encountering is Windows is using the IG services, But your macOS install is trying to use the DG services. There is nothing you can do to fix this other than replacing the logic board. But we can tell the OS to use the IG services to run macOS!
3 Comments:
After trying many time finally I found my Pendrive had problem with installation of OS by replacing with other one finally I installed OS mac 10.13.6 now it is running very well. I hope nothing happens again.
by
Also I changed the paste termical.
by
So the issue was a bad OS installer! And/or corrupted system firmware which the installer fixed.
by
Add a comment
Add your answer
Armin will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 4
All Time: 281
