Released November 4, 2017. Model A1865, A1901. Available as GSM or CDMA / 64 or 256 GB / Silver or Space Gray. (Pronounced the same as "iPhone 10.")
How come the replacement screen I bought doesnt match my phone?
I have an iphone x and was trying to replace my screen. On the left is the screen i received - it seems to have support brackets all the way around and does not fit my phone. However, my original screen does not have these brackets and is flat all the way around. Does anyone know what my problem is + why my iphone x seems to be different than the normal one?
Update (05/30/2021)
if this is the correct screen…how are these tabs supposed to fit into what looks to be a flat bracket covering?
Update (05/30/2021)
also comparing other iphones online, mine looks to be a bit different with this top area as well? anyone know whats going on here?
3 Comments
How did you remove the old bezel from the phone?
by
I have the same problem I bought a new screen for my daughter and it have these metal hinges but on hers it’s flat very confused did you find out what screen you needed I definitely need some help
by
I have the same problem but on my iPhone X there is no metal clips whatsoever it is completely flat even on the iPhone X there is no place for the metal clips to go it I’m confused
by
Add a comment
Chosen Solution
I think it snap of of the original screen and sit stuck in the housing, take a look if the part is still left in the housing and take it out.
Score 1
Add a comment
Most Helpful Answer
You’ve torn the bezel off the screen, normally it doesn’t happen, usually it happens with phones that are heavily corroded by sweat, or you’ve got a non-original screen to begin with, the bezel wasn’t attached to the screen securely on those screens.
Score 2
2 Comments:
@Spencer Lott you still have the bezel on the phone, pull it off.
by
you are the man
by
Add a comment
Add your answer
Spencer Lott will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 39
All Time: 902
