Released September 21, 2018. Models A1920, A2097, A2098, A2100. Available as GSM or CDMA / eSIM or nano-SIM / 64, 256, or 512 GB / Silver, Gold, or Space Gray. (Pronounced "iPhone 10 S.")
398 Questions View all
Screen will not wake after replacement.
I have just replaced the screen on a friends iphone xs. I removed battery first and followed the guide to the letter. When i first turn on the phone the screen comes on, i put in passcode and can use apps, surf the net everything. As soon as i lock the screen or it locks itself, then it will not turn back on. The phone still works as i can feel it vibrate and can soft reset it. After soft reset, the screen works again, until locked. Anyone else had this problem?
Add a comment
1 Answer
Hi, put the old screen back and see if problem is go away. So you know if it is a faulty screen you received or it is a other problem.
1 Comment:
Hello. Yes i tried the old screen and that works fine, as it should. Never seen this problem before. Screen come on after boot and soft reset but just will not wake off button, tap or lifting the phone. I thought it must be the screen, just know there are so many issues when changing parts on apples. Many thanks Leslie
by
Add a comment
Add your answer
Trevor Webb will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 56
