Repair guides, support, and troubleshooting information for the first 13-inch MacBook Air to feature Apple's Arm-based M1 SoC (with an 8-core CPU and up to an 8-core GPU). Released in November 2020 and identified by model numbers A2337 or EMC 3598.
175 Questions View all
Charging of the battery
Why does the charge of the battery get down from 100 to 96 while the Mac is shutdown?
Add a comment
1 Answer
Chosen Solution
Because your system is not fully off, its just in standby. So you’ll find the battery will slowly drain over a week.
To be sure and get a better view of things, install this gem of an app! CoconutBattery take a snapshot of the apps main window and post it here for us to see Adding images to an existing question
Score 3
3 Comments:
it takes from the battery 3% however I fully off the devices (shutdown), however I left the device in shutdown for 6 hours, I added the the screenshot
by
@zyad housam - TouchID logic will slowly drain the battery. Its possible you have something else which is draining the battery like a failed component or corrosion damage.
This is still quite small to fight over and the costs could be expensive to fix. Take your system to an Apple Store to get an estimate to fix (should be free)
by
Alright, thanks
by
Add a comment
Add your answer
zyad housam will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 63
