{A1989 / EMC3214}—Released in July 2018, the 13" MacBook Pro features quad-core i5 and i7 processors and Intel Iris Plus integrated graphics.
199 Questions View all
Low screen backlight after display replacement
Hello all,
I have replaced the broken display of my MacBook Pro 13 A1989 with an original display of the same model coming from another MacBook.
The backlight of the display is super low, I can barely see any image, while keyboard light, Touch Bar, webcam, Touch ID, and so on, work great.
I have tried resetting the SMC, but there was no change.
Any idea if I plugged anything loosely so the display can’t get enough power, or something like that? The replacement display was working.
Thank you!
Here is a picture of the connection to the display:
Here are a couple of close-ups on the display cable and socket:
Add a comment
1 Answer
Chosen Solution
This is one of the few cases the display cable from the logic board to the T-CON could be bad or have a bent pin/contact.
Take some pics of the connections and post them here, do make sure they are in focused Adding images to an existing question
Update (05/09/2021)
OK the cable in question is this one pointed to in Step 19 here MacBook Pro 13" Touch Bar 2018 Screen Replacement disconnect the other side and flip it over to see the contacts and inspect the socket connections.
Here’s the cable in question MacBook Pro 13" Retina (Mid 2018-2020) Display Cable
MacBook Pro 13" Retina (Mid 2018-2020) Display Cable Image
Product
$14.99
iFixit Image
Guide
Difficulty:
Very easy
2 - 5 minutes
MacBook Pro 13" Touch Bar 2018 Screen Image
Guide
Difficulty:
Moderate
1 - 2 hours
Score 1
7 Comments:
Thank you! I've attached a picture of the current status in the main post, do you need me to unplug something to provide some details? I'm a newbie, sorry!
by
I've added a couple of pictures of the display cable, are they detailed enough? Do you think it might be the cause?
Thanks!
by
@giantronik - The T-CON socket looks a bit off top right corner. I'm suspecting this is a bad part. Can you exchange it for a new one (display assembly)?
by
@danj thank you for your feedback. Looking at the pictures, you mean the part in the bottom with the codes written, that comes with the display, or the part on the top, the one near the spudger? I could return the display and get a different one. Thank you
by
@giantronik - I would swap it out.
by
Show 2 more comments
Add a comment
Add your answer
Gianluigi Persano will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 5
All Time: 183
