Fourth generation iPhone. Repair is straightforward, but the front glass and LCD must be replaced as a unit. GSM / 8, 16, or 32 GB capacity / Model A1332 / Black and White. This page aims to help users troubleshoot, fix, and seek help for the iPhone 4.
2375 Questions View all
No Service when sim inserted
Hi everyone , i bought a used iPhone 4, he told me it's factory unlocked , anyway when i insert the sim card it says no service at the top instead of the signal bars . is there a way to fix this ?
Score 3
Add a comment
Chosen Solution
clean the sim card and try again, try a different sim card, also check with phone company that imei is not blocked?
Score 3
3 Comments:
Hi , i took it to a cell shop to check it out , he told me that someone played with the reception in it on the board and it can't be fixed, but i wont give up and leave my iPhone an iPod .. and my imei is not blocked i alrdy checked that , any other suggestions ? i know your a pro and i hope u can help me out bro thanks .
Regards.
by
is he having a laugh? I think the best thing to do here is take it to another shop for a second opinion or open it yourself to see if there is any damage. Look at the sim slot/tray iPhone 4 Teardown step 13..you can see the gold prongs that the sim contacts onto, make sure they are straight, not flattened, dirty etc. At the bottom is a fine gold wire that moves when the sim inserts. You also need to take a look at the antenna connection from dock to logicboard...it may be this he is saying is damaged. A good phone repair shop/electronics shop should be able to fix that if they have the right tools. It's hard to accept that a phone otherwise working is beyond repair unless he has shown you the damage...
by
Hello , i am thinking of taking it to another cell shop , i don't want to open it myself , but do you think it can be fixed? i really would like it to be fixed since this is my second iPhone 4 , my first one was bricked cause of water damage and now it turned into an iPod :S
by
Add a comment
try a sim turbo,it costs around $2-$5 only then try to search on the net hot to open it,it works but it's a lomg process.it's not a factory unlocked phone.
1 Comment:
Hmm i guess the cell shop tried the gevey sim , but its worth a try .
by
Add a comment
Add your answer
Bahij will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 2
All Time: 8,525
