iMac Intel 27" EMC 2309 (Late 2009, Core 2 Duo 3.06 or 3.33 GHz) ID iMac10,1, EMC 2374 (Late 2009, Core i5 2.66 GHz or Core i7 2.8 GHz) ID iMac11,1
Dead shock I'm almost dead
Man ... I repaired a lot of iMacs. But this is the first time I have received a fatal electric shock from the power supply. It was horrible ... why does it come like this ... And it doesn't work at all ...
IMac power supplies are harmless, right?
Add a comment
1 Answer
Chosen Solution
Far from it! ALL power supplies have capacitors!
These can hold affair amount of energy. So when you cross your hand across the contacts you can get a very good Zap! Touch one contact with one hand and the other from the other and you can stop your heart! With dire conquests
iMac Intel 27" EMC 2309 and 2374 Power Supply Replacement In Step 10 there is a very clear warning!
“The next few steps bring your hands close to the exposed face of the power supply. To avoid a high voltage shock from the many large capacitors attached to the board, do not touch the face of the power supply.“
Score 2
Add a comment
Add your answer
ajimoza10 will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 9
All Time: 347
