Repair information and guides for the iPhone 8 that was released on September 22, 2017. Model: A1863, A1905
Home button and camera flex
My home button and front camera flex got torn is it still working?
Add a comment
Most Helpful Answer
Unfortunately there is nothing that can be done about a torn cable sorry. Replacements would function for a button/camera, but the touchID wont work again.
Score 2
Add a comment
If you tore the home button cable that goes from the motherboard to the display you can do a screen replacement and that should fix the home button but if you tore the actual home button itself then there’s not much you can do. A skilled micro soldering tech might be able to fix it but you’ll most likely need to replace the button, resulting in a loss of TouchID permanently. As far as the front camera flex that’s an easy replacement however you’ll lose TrueTone unless you can retrieve the serial number and transfer it to a new front camera assembly.
Score 1
Add a comment
Add your answer
griffithalexy14 will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 44
