Model A1347 with 2.4 or 2.66 GHz Core 2 Duo Processor.
mac mini 2010 High Sierra Handoff or Airdrop activate
Hello guys
I want to use handoff or airdrop in my mac mini, do I need a new airport card?
If necessary, please provide us with a compatible list.
I've already tried Bluetooth dongle, but it's not activated.
Add a comment
1 Answer
Chosen Solution
Sadly, its just not possible to upgrade your AirPort. There are two aspects the hardware connection is very different between your system and the needed AirPort board and the OS level you require for your system won’t support it.
Score 1
5 Comments:
So I can't use handoff in my Mac?
by
Sadly no. Apple altered things enough to prevent it.
by
ok... :/ thank for answer
by
Hey, I used a beta version of the Continuity Activation Tool and it was activated
by
@ajsa124 - Did you read up before you used it?? How to get Continuity on an unsupported Mac
One of the biggest risks these days is RAT and Malware which your system was protected, using the tool puts your system ore at risk. I don't recommend using this tool instead if your system can support the newer AirPort board I would go that way. Sadly your system doesn't offer that as an option.
by
Add a comment
Add your answer
TS Ryu will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 3
All Time: 308
