Revamped version of the iPhone 3G with faster processing speeds. Repair of this device is similar to the 3G, and requires simple screwdrivers and prying tools. Model A1303 / 8, 16 or 32 GB capacity / black or white plastic back.
1500 Questions View all
My sim card will not eject...
I am using a genuine sim card ejector tool and it will not budge. I have just been tampering with the iphone replacing the rear panel so must be something Ive not done right.
Going to take it apart tomorrow but what bit should I pay close attention to, what part ejects the sim when the tool in inserted.....?
Score -1
Add a comment
1 Answer
Chosen Solution
there is a little plastic flipper on the rear case at the top of the sim tray slot opening, it's about 5mm long, that has a plastic edge that sits behind the insertion hole, and another plastic edge that sits down into the case. Not all cases come supplied with one.. you'll need to take the old one out of your old case. The new case may not have a drill hole but using a hot pin to make a starter hole or a good amount of pressure is usually enough so that you can insert the screw.
Score 4
1 Comment:
ps, you should only need to remove the display to manually remove your sim tray and put the flipper in. just make sure the phone is off before attempting any repairs.
by
Add a comment
Add your answer
Aidan will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 1
All Time: 1,082
