Second generation of iPhone. Model A1241 / 8 or 16 GB capacity / black or white plastic back. Repair is more straightforward than the first iPhone. requires screwdrivers, prying, and suction tools.
1158 Questions View all
How to open case with stuck rubber seal?
I am trying to open my iPhone case, removing the display assembly, however the it seems to be VERY stuck, so much that when using a case opener or suction cup it pulled the glass off the top and not the whole assembly. How can I get this thing apart, I have all but ruined the case opener tool trying to wedge it around the seal with no luck. Any suggestions?
Score -1
2 Comments
What damage has it sustained?
by
I was trying to open it to clean the speaker ad try to fix the volume up button. I have previously been able to open it up via suction cup not now since the adhesive isnt holding.
I just replaced the adhesive for the bottom part of the glass and once I let it sit for a bit will try the suction cup again.
by
Add a comment
1 Answer
Chosen Solution
dud if the glass lifts, let it, then use something metal (i use a small flathead screwdriver) to get the assembly out whilst holding the glass out of the way.
Add a comment
Add your answer
adidascchs will be eternally grateful.
Past 24 Hours: 2
Past 7 Days: 2
Past 30 Days: 2
All Time: 3,374
