The Nexus S is a smartphone co-developed by Google and Samsung was the first smartphone to use the Android 2.3 "Gingerbread" operating system.
28 Questions View all
Left vertical Area unresponsive
I bought a uses nexus S and found that it had an unresponsive to touch area of the screen. This area is a 1cm large rectangle.
Which parts should i replace to get back a fully working screen?
Score -1
Add a comment
1 Answer
Chosen Solution
Montasser Ben Gadri, usually when the digitizer (touch) is unresponsible at a certain area of your screen, it is the digitizer that needs to be replaced.
Score 1
4 Comments:
Thank you very much for your answer. Is it easily replacable? Where do i find the cheapest place for nexus s digitizers?
by
Thank you for accepting my answer. Sorry, nothing is ever really easy, but it is not a bad job. Check on the teardown Nexus S Teardown it does give you a good idea what's involved. You can also check om here http://www.repairsuniverse.com/samsung-g... As for the cheapest place, it really depends on your geographical location.I tried Google and average price ~$120....Hope this helps.The reason for that is cause the Digitizer and the LCD are a lot easier to change as one unit....
by
http://www.ebay.co.uk/itm/New-OEM-LCD-Sc... $80... but it's from china, so you'll have a wait on delivery.
by
Thank you for your great help.
by
Add a comment
Add your answer
Montasser Ben Gadri will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 2
All Time: 704
