Mid 2012 model, A1278 / 2.5 GHz i5 or 2.9 GHz i7 processor.
Installing 2 new SSDs
Hello,
im currently fixing up my girlfriends old MacBook 2012 13”
I’m having issues with my bootable drive with Catalina on it. It’ll get to install section and when it starts to install it’ll have a weird error or it will go into the screen with a folder on it.
after doing research I’ve found that people will usually connect their ssd to a Mac, and install it directly onto it like that. I have yet to do that process yet but will it work with 2 ssd? I’m replacing the HDD too.
don’t know if this helps too but I also replaced the ram with 16gb
5 Comments
What are yourSSD's? Make & model as well as size.
by
Samsung 860 EVO 500GB 2.5 Inch SATA III Internal SSD
by
They fit properly when installed, but would it work if I were to just install them via connecting to my Mac that’s working and use disk utility + installer to install directly?
by
@Christopher Gimeno - What is the other drive?
by
They’re both the same
by
Add a comment
Chosen Solution
You’ll need to decide which drive will be your boot drive. With it located where your HDD was you’ll set it up as the Boot drive. But we are still a few steps ahead here!
First you’ll need to replace your HD SATA cable as its likely the older version which can’t support SATA III (6.0 Gb/s) data flows and/or its worn! Your Hard Drive Cable Is A Ticking Time Bomb. Here’s the cable you’ll need MacBook Pro 13" Unibody (Mid 2012) Hard Drive Cable and here’s the guide to put it in MacBook Pro 13" Unibody Mid 2012 Hard Drive Cable Replacement. So place a strip of electricians tape as outlined above. But we do need to be careful in handling the cable as you can easily damage it! You don’t want to crease it, instead you want to use an old BIC pen ink straw as a bending brake to form a nice arc not exceeding the radius of the straw where you need to bend the cable around a corner.
OK after getting the boot drive installed you’ll need to then install the OS onto your boot drive. I’m suspecting your girlfriends Mac was running Sierra or older macOS which uses HFS+ unlike High Sierra and newer! Which uses APFS. During the OS install process to this systems drive the installer will update the systems firmware and upgrade the file system on the current drive.
But I really don’t recommend going to High Sierra or the newer Catalina release. This is where you need to remember older 32bit apps won’t work under Catalina and as this system is SATA based it really works better under HFS+! APFS is really ideal with PCIe/NVMe drives as they offer deeper buffering with its more chatty dialog.
In any case I would recommend you download a fresh OS installer image from here: How to get old versions of macOS. Then follow this guide to create a bootable USB thumb drive installer How to create a bootable macOS Catalina installer drive or How to create a bootable macOS Sierra installer drive
Then install your second drive prep it up with Disk Utility as your data drive.
This cable connects a SATA I, SATA II, or SATA III hard drive to the logic board. Image
Product
$34.99
Add a comment
Well, since you want it installed across 2 SSD’s, you’re going to need to put them in a RAID configuration. Boot a macOS install USB on your other Mac, and install it on the volume. It should work.
4 Comments:
Hold On! You don't want to setup RAID here!
I love RAID setups, but laptops won't benefit from it and it puts your data at risk if you loose one drive (either HDD or SSD).
Dual drive setup is by far the better approach! Having a Boot drive and the second drive is a Data drive. Then its more a question of drive sizes which fits better as the Boot Vs the Data.
by
Yes I would prefer to have them not in raid since it’ll be safer and the differences are small.
Or that’s what I have heard. Is raid that much worth it?
They are both 500s
by
@Christopher Gimeno - In a desktop with dual/quad SATA interface designed for RAID I would go for it!
But, that's not what we have here in a laptop. You have two SATA ports being serviced by a laptop class PCH chip.
Your systems SATA interfaces are SATA III (6.0 Gb/s). If you need still more performance then you need to get to a PCIe/NVME based MacBook Pro system.
by
@Christopher Gimeno RAID would be great, but if you don't want it, theres not really a way to install macOS across both drives. It would be better to use one drive as your boot drive and the other just for storage.
by
Add a comment
Add your answer
Christopher Gimeno will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 11
All Time: 201
