Model A1989, EMC 3358. A refresh of the existing design, with updated processor options and a change to the keyboard materials. Available in Silver and Space Gray. Released in May 2019.
How to make external display active with dead internal display
I got in an a liquid damaged MBP. The internal display is not working. An external display does work but all it’s showing is the users desktop image. I need to make it the active screen so I can get into Terminal to turn off the auto-boot. I’ve forgotten how to do it. Also any hints on what to look for on the liquid damage would help. Thanks. @danj
Add a comment
1 Answer
Most Helpful Answer
@mayer - Did you close the lid?
Using an external keyboard and mouse you should gain access to the primary display window after you close the lid.
Score 2
3 Comments:
@danj That works, Thanks. Any idea of what to look for as to the failure of the internal display?
by
@mayer - Likely a blown T-CON board. A common issue in this series as they run too hot!
by
The kid woke up and realized it was covered under his AppleCare after I cleaned it. Did do a Time Machine backup and restore his data onto a new MBP.
by
Add a comment
Add your answer
mayer will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 186
