There are several types of PowerBook G4 Aluminum models.
888 Questions View all
idea how to added a sata hard drive to a power book!
i was thinkin of getting a (2.5 sata to 2.5 ide adapter)
http://www.amazon.com/2-5-inch-SATA-Driv.... do guys think that it would work,i know space would b a issue but i cross that 1 when am there
http://www.ebay.com/itm/7-15P-Serial-SAT...
http://www.ebay.com/itm/2-5-SATA-SSD-HDD...
Add a comment
Chosen Solution
I don't believe this is possible because of the space issue you mention. I am including a link to the hard drive replacement and ask you to pay particular attention to step 12. You will notice the drive is connected to the logic board by a short cable that would be out of position even if the adapter didn't short out the logic board. I would suggest staying with the IDE drive. Good luck whatever your decision.
PowerBook G4 Aluminum 15" 1.5-1.67 GHz Hard Drive Replacement
Score 3
Add a comment
As rj713 said, space would definitely be an issue. However, have you thought of perhaps adding a SSD instead? http://eshop.macsales.com/shop/SSD/OWC/M...
Another idea would be to remove the superdrive and replace it with a sata drive. Doing a quick google search came up with MCE's optibay http://www.mcetech.com/optibay/ as an option. Theoretically, I would think you could probably also get away with an atapi to sata adapter.
Just my 2 cents. Best of luck!
Score 1
Add a comment
Add your answer
wooly will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 620
