Model A1311 / Mid 2011 / 2.5 & 2.7 GHz Core i5 or 2.8 GHz Core i7 Processor
427 Questions View all
2011 21.5" iMac Logic Board Repair Help!
Hey guys!
So I just picked up a 2011 21.5” imac. Previous owner said it wouldn't turn in, put in a replacement powersupply, and still wouldn't turn on. Upon further inspection, only the 4th LED lights up (technically LED #1) and nothing else lights up. I tried using the spare PSU I was given, and a 27” PSU I had laying around. Still nothing, so I assumed it's a logic board issue.
I don't see any damage or corrosion on the board at all, is there a common failure point in these boards I could attempt to pinpoint and fix? I really don't want to spend money on a logic board.
Add a comment
1 Answer
The most common issue is the MXM GPU board fails.
If the system had been sitting awhile unplugged you likely need a fresh PRAM battery as well.
5 Comments:
Would the bad GPU cause the system to not boot, and the other diagnostic LEDs not light up?
by
Yes, a short can do that. I've seen a few that had a bad cap.
by
@danj if I remove the GPU, could I attempt to power it on with it removed? I know I won't get any display image, but hoping to see more diagnostics LEDs light up
by
In its self it won't offer enough information diagnostically. I mostly use a DVM to test the power rails and VRM's
I have a few spare GPU boards which I could use to test things. Rarely have I needed to do that. But thats me not someone who is a DIY fixer.
Do you have access to a second known working iMac or the same series which you could borrow the GPU board.
by
@danj I don't, but I ordered a barebones logic board for $40
by
Add a comment
Add your answer
Corbin Titus will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 1
All Time: 63
