Mid 2006 / Model Number: A1181 / black or white case / 1.83 or 2.0 GHz Intel Core Duo processor
418 Questions View all
Won't boot all the way up
I am trying to fix this for a friend. It is a white macbook, I don't know for sure whether its an a1181, the writing on the bottom is rubbed off the case. When you hit the power button it will get to different stages of the start process, but it doesn't stop at the same spot consistently. sometimes I can log on and start toying with it, other times it will get to the apple screen and stop, and still other times there will be just nothing. any help will be appreciated, thanks
Score 1
1 Comment
I don't know if it is related, but I also just fired it up and got it working, but then the backlight went off.
by
Add a comment
1 Answer
Chosen Solution
Try starting up from your system installation disk, "C" key. Go to the second screen pull down menu to Utilities > Disk Utility. Select your hard drive in the left hand column. Run repair of the drive till it runs clear, then repair your permissions. Let us know your results.
Score 3
2 Comments:
I tried to do this however I can't because it won't boot off of the disk
by
That's not good. Try it in Target mode with another Intel Mac and a firewire cable.
by
Add a comment
Add your answer
Trent will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 3
All Time: 475
