2.3GHz, 2.6GHz, or 2.7GHz quad-core Intel Core i7 processor (Turbo Boost up to 3.7GHz) with 6MB shared L3 cache.
Need a Logic board upgrade, help
Hi
I have a “15 retina display mid 12(A1398) 2.3ghz, i7 quo-core, 256gb, 8gb ram. (im from italy)
My logic board just died on me. Since I need to buy a new one, can i just buy the the 2.7/8 ghz, 16gb ram? Will just fit right for my pc? if the answer is “yes".
Also can i buy a Samsung 960 evo SSD for this new Logic board and will it fit?
which kit do i need to buy from ifixit.com to get this job done? thank you very much.
Add a comment
1 Answer
Most Helpful Answer
While you can replace the logic board with one that was designed for your system MacBook Pro 15" Retina Display Mid 2012 Logic Board Replacement finding a replacement will take some effort I haven’t seen one available from my typical supplers. I would be careful on any jobber listing on Amazon or eBay.
As far as the SSD this series uses a mSATA drive so the Samsung 960 won’t work as its a PCIe/NVMe drive. Review this guide for more details: The Ultimate Guide to Apple’s Proprietary SSDs
Given how much you want to change I would recommend you look at just buying a newer used system. I would recommend going with a 2015 model. Just be aware there is two different versions of the last retina’s MacBookPro11,4 - Intergrated Graphics and MacBookPro11,5 - Dedicated GPU so make sure you get the one you want.
Score 1
3 Comments:
Thank so much for you time and answer on this. I already did a quick research on a new version but giving the time we are living in and my tight pockets i can't afford a “new” used version. my same mac still selling for over €750.
i rather spend 300 to 400 and have a “top of the line" mac. i dont know much about macs, but mine doesn't seen far behind the new ones. I use my mac for video, photo editing, programming and Machine Learning using the nvidia card that have on it.
by
@banginpadr - I hear you! The problem is finding a 2012 logic board, you might be able to install an Early 2013 board. Thats the best you can do. But the cost is still a bit steep MacBook Pro 15" Retina (Early 2013) 2.7 GHz Logic Board $650 USD. That still doesn't address the drive upgrade you where also looking for. This systems drive I/O is constrained to SATA III (6.0 Gb/s) of the mSATA interface.
The only option is get around that would be to get a USB 3 or Thunderbolt 2 external SSD drive.
I just found a used system for $560 USD on eBay that looks very clean! 2015 15" MacBook Pro - MJLT2LL/A Just be careful!
15" MacBook Pro 2.5 GHz Core i7 Mid-2015 (DG) While not a 2.7 GHz it offers more performance than the 2012 model with the higher speed SSD.
by
i see, thank you very much i will start considering my options then.
by
Add a comment
Add your answer
Boss boss will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 8
All Time: 217
