The March 2015 update of Apple's 11" MacBook Air features fifth generation Intel Core i5 and i7 processors, resulting in slightly increased performance and battery life.
134 Questions View all
My MacBook does not turn on but it still charges
My laptop does not want to power on. If I connect the charger it still charges but it doss not turn on.
I tried resetting the SMC and NVRAM but nothing happens because it won’t turn on.
If I press the on/off button, the start up fan sounds like its about to sound to turn on but it immediately stops. No light comes on the screen. What should I do?
Add a comment
1 Answer
Sadly, this sounds like a logic board failure with the CPU logic on it. Here’s the guide on whats needed to get to it: MacBook Air 11" Early 2015 Logic Board Replacement and you’ll still need to find a replacement logic board.
This system RAM is limited to 8 GB so it might be cheaper to get a newer used MacBook Air and place your current SSD drive in a case so you can access your data.
Add a comment
Add your answer
Kimmy will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 45
