Repair information and guides for the iPhone 6 Plus that was released on September 19, 2014. Model: A1522, A1524
1525 Questions View all
battery replacement screen stopped working
Replaced the battery, phone worked for a couple days, then screen started to malfunction. Took phone apart, checked logic connections, phone worked again for a few days, then same problem with touch screen not working/unresponsive. Took apart again, checked logic/screen connections and phone is now non-functional/scrambled screen only. Can I replace any of these connectors or is the phone aced?
Add a comment
1 Answer
Chosen Solution
Unfortunately I’ve had this to me a few times after a battery replacement and 9/10 it always comes to the touch ic chip on the board. If you can replace yourself, cheap fix otherwise if you have to take to a repair shop they usually will tell you to upgrade as it isn’t worth the repair as it is a very common fault.
Score 1
Add a comment
Add your answer
Dirty Perry will be eternally grateful.
Past 24 Hours: 2
Past 7 Days: 4
Past 30 Days: 4
All Time: 63
