4-inch iPhone released in March 2016 with similar hardware specifications to the 6S. Available in Silver, Space Grey, Gold, or Rose Gold with 16/32/64/128 GB storage options. Model: A1662 and A1723
No backlight NO Image problem
Hello Guys! This is an advanced question.
iPhone SE NO backlight and NO image. I have already replaced every components on the backlight line (filters, diods, IC)
The Original screen is working for SURE (tested it)
Mainboard connectors are all tested good.
Phone works, and boots I know because when I plug in the charger cable the charging sound comes in.
What is the next step to do to further investigate?
Blow photos are taken right after I opened up the phone:
Update (11/24/2020)
Thank you for taking the time for answering. Unfortunately I have decided to stop investing time for now. I have other stuff to do so I’ll put it for side now. :)
2 Comments
How is the display driver?
by
@mrgeek Display driver has been changed to a new one.
by
Add a comment
1 Answer
Chosen Solution
Forget about the backlight until you have image. You said mainboard connectors all tested well. So you are getting
·         1V8 on pin 5?
·         5V7 on pin 1 and 3?
What are diode readings of pin 7 and 9?
Score 4
Add a comment
Add your answer
Peter Hupuczi will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 6
All Time: 556
