Repair information and guides for the Apple iPhone 5s that was announced on September 10, 2013. Model: A1533, A1453, A1457, A1528, A1530, A1518
3530 Questions View all
Weirdest issue with lock button
Suddenly my lock button only works for turning on the phone, waking and clicking 5 times for emergencies. Lock and turning off doesn’t doesn’t work - and the weirdest part is that the phone can’t even lock if i use the assistive touch function (software?)
I’ve tried reseating everything inside, as well as resetting settings in software.
Yes…the auto lock is set to 30seconds
thank you !
Add a comment
1 Answer
Sounds like a base-level issue with the software. Have you used a computer to reset the settings and software, or only by selecting that option in the phone settings?
I would recommend following this guide on iFixit to put your phone in DFU mode, and then using your computer to install a fresh copy of the firmware from the bottom up. That would be the most likely fix.
Add a comment
Add your answer
Oscar Velay will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 3
All Time: 34
