The Samsung RF28HDEDB is a 28 cu. ft. refrigerator featuring a Twin Cooling Plus® system, LED lighting, spill-proof slide-out glass shelves, and multiple convenient features, with dimensions of 33 3/4" x 68 7/8" x 35 3/4".
My Samsung ice maker works, then doesn't, then works, then doesn't
My 4yr old Samsung RF28HDED refrigerator with ice-maker in upper left location just stopped making ice about 2 months ago. This is NOT the ice maker getting jammed and freezing into a block of ice issue. We did have that issue but that was addressed (y-clips installed, sealant at bottom of ice room, etc..). After the fix, had no problems for 9 months. Worked perfectly. Then one day no ice. Freezer temp = 0 degrees. Ice maker is ON. New Samsung water filter. Water dispenser works fine and I get almost 1.5 cups water in 10 secs. Bottom freezer working fine, no melting ice cream or anything. If I push the reset button on the ice maker, I hear the chime and about 10mins later, perfect ice cubes dump into the bucket, but that’s it, no more ice. I ran the status test (touch [freezer] + [refrigerator] buttons simultaneously ) and the indicator light for the ice bucket shows flashing (meaning that the fridge thinks the ice bucket is full). It is not full. Supposedly you are able to take a picture of the emitter with your cell phone and see the IR light. I did not see any light. So I replaced the auger motor that includes the IR emitter thinking it was defective. No change in ice production or status indicator (still blinking). Oddly, then about 2-3 weeks later, the fridge just started making ice and wouldn’t stop for 3 days. Just continually making ice. We had to keep dumping the ice bin. I checked the status indicator at that time and the light was not blinking. Continually on solid- meaning now the fridge thought the ice bucket was always empty even when it was overflowing. But then after 3 days… it just stopped making ice again and the status indicator changed to blinking again. So I replaced the PCB on the back of the fridge. Thought for sure this would do it. But again, no change in ice production and the status digit continues to blink. I hit the reset button on a daily basis and it obediently makes one tray of ice then quits. I am at a loss of what to do next… any help or suggestions would be much appreciated. Thanks.
Score 4
6 Comments
I am having the exact same issue, the IR sensor appears to be dead and I have not replaced the auger assembly yet. I am worried I will just be sinking more money into this terrible ice maker. I have already replaced out the maker portion twice and installed the y brackets and sealed the ice box area. I was wondering if you ever solved the problem and what your solution might have been. As it stands now I am basically pushing reset every few hours to get it to drop some ice!
by
I've had exactly the same problems. I paid almost $500 between service call and part to get it fixed and lo and behold it is not working again after only 10 months.
Samsung, this is a defective component and you should fix it for just a service call by your authorized repairman. I will never buy another Samsung refrigerator again.
by
No answer to help. I’ve been having same issue, except reset button doesn’t help at all. It just doesn’t make ice for a few weeks to a month, then makes ice for a while, then stops again.
by
Gawd. I found your post and this is the exact problem I have. I’ll keep resetting and finally one day it will work. And continue to work for MONTHS.
I called Samsung and they’re obviously to what I’m saying
by
Exactly the issue we have with our unit, it makes ice nicely for two weeks and then nothing. It is so frustrating that you spend all this money on a refrigerator and after the warranty runs out it goes and does this. And the water filters are extremely costly as well, Lowe's for one filter is $60.00 that you are supposed to change every 4 months. You all are much talented than I with all the codes and IR stuff, I just want the darn thing to work properly. I won't buy another one that's for certain.
by
Show 1 more comment
Add a comment
Most Helpful Answer
Hi @scubaboy12 ,
Don’t know the answer but hopefully this link may be of some help.
It shows how to get into the diagnostic mode for a Samsung RF28HDEDBSR refrigerator so that you can check if there are any error codes pertaining to the ice maker, (see p.61 for ice maker error codes). Maybe it is the same for your particular model variation
On p.73 there is a flowchart that shows the procedure for when there is a problem with the ice maker (refrigerator) sensor and on p.74 for the ice maker (freezer) sensor.
Score 2
3 Comments:
Hi jayeff,
Thanks for the info. I really appreciate it! Will check out the link and continue the fight.... thanks again! Will post back if any progress.
by
I have a 4 year old Samsung French door refrigerator. Ice maker has been replaced twice and now it’s not working again. Samsung knows about this problem but refuses to fix it. Buyer beware! Wasted $2,000 on a black stainless steel model. Never again.
by
I have a Samsung Refrigerator RF28HMEDBSR ice maker has been replaced 2 under warranty and I have replaced it twice in a ten year span now it will freeze ice but won’t dump sometimes it will when you push reset button and sometimes not have unplugged reset checked front panel ice maker is on very frustrating to have a kitchen full of Samsung products and every one has had to have work done on or replaced will never buy any thing that says Samsung on it
by
Add a comment
I don’t have anything to contribute other than my ice maker is doing this exact same thing. I see light on my IR emmitter and there are no codes at all. The icemaker works fine for about a day after a reboot then it stops. It will make a single tray of cubes with a reset.
I haven’t yet tried changing any of the values regarding temperature or icemaker drop frequency in the linked manual above, maybe that is the next step. Another idea I have is to put it on a smart switch and have the fridge be automatically power cycled once per day, but this is a hack and I would like to fix it properly.
Score 2
1 Comment:
Hi John, I too have the same issue and had the same idea of auto resetting once a day. I have found that a reset and jiggling the wire connectors or even disconnecting and reconnecting them will keep it running well for about a week. Have purchased many of these ice makers on Amazon and found it is the timing gear inside the thing that ends up with broken teeth. First time this happened my son had bought me a 3D printer and I was able to find and print the gear @ https://www.thingiverse.com/thing:324678... - this lasted about 6 months then the smaller gear driving it broke... this is when we would buy another unit sold as "new" but no doubt refurbished. Same issues and a year later buy another. I have yet to open our current unit that works when reset but suspect a tooth is missing on the gear above - now out of warranty I may eventually open it to see. If you decide to print a gear, be sure to install the original square magnet in the same orientation as it may affect the FET cycle sensor.
by
Add a comment
Add your answer
Michael will be eternally grateful.
Past 24 Hours: 6
Past 7 Days: 53
Past 30 Days: 208
All Time: 13,238
