Fourth generation iPhone. Repair is straightforward, but the front glass and LCD must be replaced as a unit. GSM / 8, 16, or 32 GB capacity / Model A1332 / Black and White. This page aims to help users troubleshoot, fix, and seek help for the iPhone 4.
2376 Questions View all
How do I replace only the home button and not the ribbon?
My question is how do you replace just the home button and not the ribbon. Say I have a white iphone 4, but want to make my home button black how would I do this and is it fairly easy?? Thanks
Score -1
Add a comment
Most Helpful Answer
It's just to replace it.
You have to move the "push-funktion" from the old one to the new button.
It's fasten with glue so you can just remove it carefully and move it to the new button.
Score 1
2 Comments:
Well I bought a black home button already, now how do I remove the old home button?
by
Add a comment
This answer was originally to another question.
There really is no shortcut to doing a job right. The best way it to take it apart and replace it.
Score 1
Add a comment
look in the repair manuals under home button replacement?
Score 1
Add a comment
I believe the best option would be to take it apart and do it. You would probably end up ripping the flex cable if you tried the short way.
Add a comment
Add your answer
Austin will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 4
All Time: 631
