Repair guides for the MacBook.
3787 Questions View all
My MacBook keyboard stopped working.. how can I fix it?
days ago, my 13" macbook started having problems. first, the highlights on a folder wouldn't go away, no matter what other folders i clicked. whenever i needed to preview pictures from a folder, it would always show the bottom half of the contents. when i had to shut down, the laptop would make these ding sounds continuously. when i tried logging in to my email account, it would show one letter filling the username field on and on. and now, the keyboard doesn't work at all.
Score -1
Add a comment
Chosen Solution
You have a key stuck down and it is continuously entering itself. Pull the keycap off the one thats entering and see if you cam clean it and get it to stop. Try using a Q-tip dipped in alcohol. If this fails you will probably have to replace the keyboard.
Score 4
Add a comment
i tried an external usb keyboard and it works. for now. but the laptop's keyboard won't work at all. is this a logic board issue?
Add a comment
m y macbook A1181 keyboard is not working after startup the caps light is on and only few keys are typing but double strikes.
any solution do have thanks
i had open the motherboard but there is no battery on board
Add a comment
Add your answer
Joel Sol Cruz will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 3
All Time: 2,110
