PS4 Controller model CUH-ZCT1. Released in November 2013 by Sony Computer Entertainment, this six-axis, 3.7 V lithium ion battery controller is uncomplicated to repair. (NOTE: Teardown guide is NOT for this model)
387 Questions View all
My ps4 control wont charge, I dont see yellow light
I controller was working a day ago, my controller analog stick is broken but I'd fixed it, but on the next day it won’t charge anymore.
My controller issue is: Broken or damaged battery, is the damaged battery is the cause of not charging?
Score 1
Add a comment
Chosen Solution
Hi!
Yes it could be your battery, but it also could be the charge/LED board.
When you put the USB cable in, does the orange light flash? If yes, battery is probably bad. If no, it could be the battery or charge/LED board.
Score 1
4 Comments:
My controller works fine 2 days ago.
What do you mean Charge/LED board?
Please help me, so that i can save money.
Thank you
by
Example: DualShock 4 Charging Port Replacement
Check the board, is the USB port still good? Does it look fine? Cable connected as it should (to the motherboard)? And do you get any type of light, or is it just dead all the time (even with trying to charge) ?
by
You mean The Back Part of Controller The that has LED that connected right on the battery?
by
Yes that’s what I meant :)
by
Add a comment
is this the board or the usb port you talking about??
4 Comments:
Yes that is the one I meant. Is it still good? Perhaps that one needs to be replaced.
by
So do i need to replace the LED or the white power connector thingy?
by
After running a few test, my controller LED light up in green but no so bright but only the LED and the rest are not working
by
When I bought my ps4 and start playing a few days later my controller was down on battery so I started to plug in the charger but couldn't see the yellow charging light.
by
Add a comment
Add your answer
Chloyd will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 12
Past 30 Days: 51
All Time: 1,560
