Repair information and guides for the iPhone 6 that was released on September 19, 2014. Model Numbers: A1549, A1586, and A1589
4994 Questions View all
Vertical lines on screen without any connector damage
I was replacing a charger port assembly and when i plugged everything back in there were lines on the screen, so bad you couldnt see anything, however i could tell it was still “on” because vibration worked when i would place a wrong finger on touch id. After cleaning the display connectors with alcohol, very lightly with a brush on both screen and phone, the lines dimmed and the phone was usable but with faint white lines. After being quite stuck i unplugged and plugged in again and it was unusable again, really bad lines, now coloured. I now put the old charging port back into the phone and it has behaved the exact same.
I have tried other screens that are cracked and broken (because its only what i had spare) however they dont show any lines, the only faults show are what was already bad with these other lcd’s. Meaning it must be something with the display correct? I didn’t do anything i don’t do with other phones that i fix fine. When i opened it, i could tell it had been repaired before (missing screws) is that relevant?
Please help, i’m on a time crunch! Thanks!
Add a comment
Chosen Solution
Sounds like you need a new screen.
Score 1
Add a comment
Second @tech_ni's opinion; certainly sounds like time for a new screen.
Any chance you connected/disconnected the screen with the battery still hooked up? That's been known to cause damage to screens.
It could always be a connector issue as well; in this case the fact that other screens work would tend to isolate that cause to the screen's connector and not the motherboard's. Get out the magnifying glass and a bright light and go over the connector and the flex cable looking for bent, broken or missing pins or any kind of damage to the cable itself.
Score 1
Add a comment
Add your answer
Jack Chadwick will be eternally grateful.
Past 24 Hours: 2
Past 7 Days: 8
Past 30 Days: 17
All Time: 221
