convection over range microwave oven lost heat convection only
Lost heat ONLY in convection oven. Microwave works fine It’s a GE profile PVM9179DFBB
Does the fan come on when you turn on convection heat?
If not it may be the control circuit for the convection heat has a bad relay or wiring problem.
If the fan still works then the heating element for convection function is likely burnt out and will require replacement I expect.
Yes fan still works. Thinking it will be too difficult or expensive to replace heating element. Thanks
for your help.
Hi @skup
You missed a digit from the model number.
If it is a PVM9179DF1BB, 2BB 3BB etc then here's the cost and location of the element - part #3019 interior parts diagram that may help. At least initially to test it with an Ohmmeter to see if it is OK or not.
If you do decide to test /replace it then be safety aware as the HV capacitor can seriously injure you if it hasn't been discharged properly before commencing any work after removing the microwave cover
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 39
