Model A1502 / 2.6 GHz (Turbo Boost up to 3.1 GHz) or 2.8 GHz (Turbo Boost up to 3.3 GHz) dual-core Intel Core i7 processor with 4MB shared L3 cache.
Issues with iFixit support
Just got the new battery replacement for a late 2014 model a d I am having an issue with a black screen and I have done everything I can possibly think to correct the issue. Resetting the Ram, configuring the battery for optimal use. Plus a new dispute ribbon into the computer and still nothing the battery works and so does the computer. I am using an external display and the computer is completely functional except fo the built in display which won’t turn on. Also back light is not on. So any thoughts. I tried to connect with a respective at iFixit and I have to say very disappointed with the gentleman I talked with. Not helpful at all and just stated I should return the item for a refund or request a new battery.
2 Comments:
This question was migrated from https://www.ifixit.com/Answers.
by
This question was migrated from https://meta.ifixit.com/Answers.
by
Add a comment
1 Answer
Hello stantermini,
Thanks for reaching out! Sorry to hear you’re having some issues after completing a battery replacement. I can’t diagnose the issue for certain, but it sounds likely that a connector didn’t get fully reattached, which can result in a display malfunction. I’d open up the laptop and make sure all connectors are secure.
Remember that you’re still welcome to take up the offer for a refund!
I’m moving this post back to the Answers forum in case one of our community members has some insight into this issue.
I hope this helps, and best of luck with your laptop!
Add a comment
Add your answer
stantermini will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 7
All Time: 104
