Question Closed
Different diameter size of fans used for the iBook?
Hello,
I repaired my ibook G4 12" 1,33GHz with a mainboard from another same model iBook G4. I noticed that my fan had a smaller diameter than the one in the other ibook I took the mainboard from.
Did Apple use different fans in the same models? My own was from Sept. 2005 and the Mainboard was from one of Jan. 2006.
On my fan there is ca. 3-5mm space from the metal frame to the fan. The other is very close, lets say only 1mm away to the frame.
Add a comment
Chosen Solution
The iBook G4 1.33 GHz came in both a 12' and a 14" model. You probably put a 14" model fan in your machine.
Apple iBook G4/1.33 12-Inch (Mid-2005 - Op) Specs
Identifiers: iBook G4 - Mid-2005 - M9846LL/A - PowerBook6,7 - A1133 - N/A
Apple iBook G4/1.33 14-Inch (Late 2004 - Op) Specs
Identifiers: iBook G4 - Late 2004 - M9627LL/A* - PowerBook6,5 - A1055 - N/A
Score 4
1 Comment:
Well, it's not me, that took a 14" model fan... but I understand, what you are saying. The ibooks I have here are both the same 12" 1,33GHz, but the former owner must have taken a 14" model fan.
Thanks.
by
Add a comment
Addition, over time I have encouterned several 12" 1,33GHz G4 ibooks mid 2005 model that have different fans inside.
Add a comment
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 1
All Time: 486
