Released October 24, 2011 / 2.2, 2.4, or 2.5 GHz Quad-core Intel Core i7 Processor
Battery Is Not Charging
new battery
new charging wire
new charging port
i have voltage in battery connector on motherboard
SMC reset
GPU - switch off
but... no battery charge, no light on charge wire, can't start without battery.
Plug\unplug charger: https://youtu.be/7rnb9v6DNEo
Battery Information:
  Model Information:
  Serial Number: D861015004NDGDL3T
  Manufacturer: SMP
  Device Name: bq20z451
  Pack Lot Code: 0
  PCB Lot Code: 0
  Firmware Version: 2
  Hardware Revision: 00aa
  Cell Revision: 2
  Charge Information:
  Charge Remaining (mAh): 544
  Fully Charged: No
  Charging: No
  Full Charge Capacity (mAh): 7800
  Health Information:
  Cycle Count: 1
  Condition: Normal
  Battery Installed: Yes
  Amperage (mA): -25
  Voltage (mV): 11350
System Power Settings:
  AC Power:
  System Sleep Timer (Minutes): 10
  Disk Sleep Timer (Minutes): 10
  Display Sleep Timer (Minutes): 10
  Wake on AC Change: No
  Wake on Clamshell Open: Yes
  Wake on LAN: Yes
  Current Power Source: Yes
  Display Sleep Uses Dim: Yes
  GPUSwitch: 2
  Hibernate Mode: 3
  PrioritizeNetworkReachabilityOverSleep: 0
  Standby Delay: 4200
  Standby Enabled: 0
  Battery Power:
  Display Sleep Timer (Minutes): 2
  GPUSwitch: 2
  Hibernate Mode: 3
  Reduce Brightness: Yes
  Standby Delay: 4200
  Standby Enabled: 0
Hardware Configuration:
  UPS Installed: No
AC Charger Information:
  Connected: Yes
  Charging: No
Score 1
Add a comment
1 Answer
I’ve just been fixing one of these tonight if theres no light on the charge wire and you’re sure the charger is good its likely a blown u7000 but its worth changing q7030 and q7031 while you’re here.
I replaced a u7000 tonight the tools I used are a MUSTOOL G1200, 858d hot air ‘station’ max heat and low air, soldering iron with 900m-t-s bent tips, leaded solder and fine tips on my multimeter. I have experience with bits of hot air soldering and its at the limit of my abilities and very easy to create a dry joint.
I appreciate this is a long and complex answer but I’d prefer the information to be here for the next guy so they dont get told to repeatedly reset the smc.
Add a comment
Add your answer
Aleksander Aleksandrov will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 13
All Time: 241
